Go Back   Automotive Forums Car Chat > Honda > Odyssey
Old 01-10-2008, 11:44 AM
arnel_h arnel_h is offline
Angry Sliding Door And Clock
I got a 02 honda odessey. The passenger side slide door won't lock and unlock by remote and the also the dash board clock light is not working. Any idea what's going on? Thanks
Old 01-11-2008, 08:56 PM
dcx96 dcx96 is offline
Re: Any Idea
sounds like you need a chrysler
Old 01-14-2008, 08:20 PM
chris asmussen chris asmussen is offline
Re: Any Idea
have you checked the fuses?
Old 01-16-2008, 03:41 PM
Re: Any Idea
yeah, I check the fuses and all fuses are fine.
Old 01-16-2008, 03:42 PM
Re: Any Idea
Sorry I don't like chrysler that's why I get honda.
Old 01-16-2008, 08:10 PM
wiseguy01's Avatar
wiseguy01 wiseguy01 is offline
Re: Any Idea
sounds like a relay or maybe your remote has a dead battery and i know you said you checked all the fuses but did you check the fuses under the hood too??
Old 01-17-2008, 07:38 AM
Re: Any Idea
yeah, I did. You know sometimes when I unlock the vehicle and push the unlock button twice, It unlock the door. I was setting inside the van and I observe the lock by locking and unlocking by using the remote and the master control at the driver side. I see that the lock knob move partially.
Old 01-20-2008, 08:57 PM
wiseguy01's Avatar
Re: Any Idea
try oiling the knob that moves get some lubricant like wd-40 spray it so it will run down in the door maybe that will work for u
Old 01-24-2008, 09:48 AM
Hwy rider Hwy rider is offline
Re: Any Idea
I am a 2x odyssey owner, '02 & presently '04, unfortunately both vehicles have the same exact issues with the clock light not working. Ironically, I recently hit a major pothole and the clock light began working again! Don't recommending doing the same but it would suggest that there is a loose/faulty connection somewhere. Beware, you might experience: light for rear temperature control knob in dash going out; volume buttons in steering column only increase volume; and last but not least... don't ever leave your radio on or key in ignition without having engine running unless you love dead vehicle! MAKE A PORTABLE CHARGER YOUR BEST FRIEND. (LOL)
Old 01-27-2008, 01:51 PM
wiseguy01's Avatar
Re: Any Idea
ive been in a 04 accord and im pretty sure they are the same when i press the unlock button once only the driver unlocks but press it twice then the whole car unlocks and also is the same when locking it and arming it
