| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
gm MAF
if I wanted to change my stock MAF to a gm one what is the best way of doin that?
Re: gm MAF
Re: gm MAF
It's quite easy really... All you need is a GM MAF off the proper vehicle and a MAF Translator and it's all mostly plug and play so long as you know how to put it into your piping for a blow through setup... It will also give you a wider range for tuning, which isn't too hard either, as long as you know the basics to proper tuning of it...
I didn't read through the article that Garrett posted, but I gave it a quick skim and it looked to be a good detailed one for ya to use.
-Brian
Re: gm MAF
What did you mean by, being careful you know how to put it into your piping for a blow through setup?
Re: gm MAF
I didn't say "being careful" anywhere?... I was talking about putting the MAF in your upper intercooler pipe which makes it a blow through setup. Rather than being before the turbo and reading the air going INTO the system, the blow through setup meters air passing THROUGH the system... A bit more accurate and it allows you to change your setup around a little bit.
-Brian
Gm Maf
Did you guys knwo that you can just buy a cable that connects to your stock MAF plug and then connects to a 3" gm MAF? And the poeple who sell them say you dont need a MAF translator?IS this true? becasue i would rahter havea 30 dollar cable than a 200 ugly box?
Re: MAF cable
Link?
Tim 1990 Talon AWD 2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink, PTE SCM5031
Re: MAF cable
Re: MAF cable
What is wrong with your other thread on GM MAF's you started two days ago??
Re: Gm Maf
What if i jsut bought the link cable and hooked it up?
it would still work for the time being right |
Re: Gm Maf
If you're going to do it, do it right. Besides, I dont think they make those straight up conversion harnesses for DSM to GM MAFs.
Re: Gm Maf
Re: Gm Maf
Yeah, right on... being that its not with a translator its not going to fix the BOV dump thing though...
Re: Gm Maf
What do you mean BOV dump thing? OFf the 02 housing? I didnt mean to put that there was a dump there.....it is recycled back into the exhaust. But this basicallt means you dont have to buy a MAF tranlator right?
Re: Gm Maf
Any reason why you want to do this particular mod? Maybe if we can get your reason as to why you're installing it, we can help you more.
