Old 02-19-2003, 08:33 PM
Santas90Si Santas90Si is offline
Registered User
Send a message via ICQ to Santas90Si Send a message via AIM to Santas90Si Send a message via Yahoo to Santas90Si
Idling about 2500RPM please help
Okay I am beginning to think I should have left the other engine in my car.
Heres what is going on now.
I start the car it revs up to about 2K and it stays there which is nothing out of the normal when its cold. But after I drive it a long or short time when I pop the clutch it goes to about 2500 or higher a second ago it was idling at about 3300. If I hit the gas then let off it will go back down to about 2k but as soon as I take off and hold the throttle at a position and then hit the clutch again same ol shit as before.
The motor that I put in it has a cam that I have no idea the duration on. The car smells like it runs rich as hell. I have an AEM timing gear on it and its retarded to the fourth hashmark. I think that means its 8 degrees off normal? Is that too much or is it impossible to tell without knowing the size of the cam?
Thanks for any help anyone can give me even if its a SUCKS TO BE YOUR ASS. YOU SHOULD HAVE INSTALLED THE CAM AND SHIT YOURSELF...thanks
Old 02-19-2003, 08:40 PM
H4Bangin's Avatar
H4Bangin H4Bangin is offline
Send a message via AIM to H4Bangin
TPS???maybe or a vacuume leak
********** My 94 SS **********
90 civic dx 4 door d16z6 - p28, aem intake, act stage one clutch, cheap header- commuter car
seth 90DX/ZC seth 90DX/ZC is offline
Banned
Ummm... Did you check the throtle cable? Maybe its sticking... Not a totaly educated guess...
Old 02-19-2003, 08:52 PM
Registered User
Well I havent checked all of my vac lines but I will do that ASAP and the TPS I have no idea and the throttle cable isnt sticking as far as I know.
Old 02-19-2003, 09:25 PM
91EF3ZC's Avatar
91EF3ZC 91EF3ZC is offline
AF Premium User
Send a message via AIM to 91EF3ZC
i am gonna go with vacuum leak.
Visit my EF page:http://www.pbase.com/luv2hover/91_civic_&page=all
Old 02-19-2003, 09:45 PM
90civicrider's Avatar
90civicrider 90civicrider is offline
www.DecepticonRacing.com
Check all your vacume lines. If possible try and get your hands on a vacume guage. Or you could try adjusting your throttle cable, maybe it's to tight.
Those are the 2 things i would check first.
Hope that helps man
||JEFF| |
Candy Orange 1990 Honda Civic H/B
Old 02-19-2003, 09:49 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
theres a plate on the throttle body that the throttle cabe attaches to. If thats bent just a little bit, it sticks and wont let the idle return to where it should go.
Old 02-19-2003, 10:23 PM
Banned
Thats what i was thinkin cause he said if he pressed on tha accelerator again it would usualy drop back down to idle right?
