Old 01-09-2008, 06:36 PM
cf1 cf1 is offline
trans problem
i have a 2006 silverado 5 speed, going from first to second gear it hangs up like its stuck between gears, any clues... only 12000 miles on it...
Old 01-09-2008, 11:25 PM
rjeffery rjeffery is offline
Re: trans problem
Take it back to the dealer, should be under warrenty.
2002 1500 Ext. Cab 4.8L 2wd.
K&N FIPK, Cat Back Exhaust, Rancho RSX Shocks, Silverstar Headlights High & Low, Infinity Reference Door Speakers & 10" Dual Voice Coil Sub. 265/75/16 BFG AT/KO's, Spray-In Bed Liner, Hella FF75 Fog Lights, Hella FF75 Driving Lights.
Old 01-11-2008, 02:33 PM
cf1 cf1 is offline
Re: trans problem
thanks i guess thats what ill do..
Old 01-11-2008, 03:05 PM
16th hippy 16th hippy is offline
Re: trans problem
while it should be a warranty fix, my first guesses would be worn/faulty 1-2 synchro. could also be air problem in clutch hyd. system...after one shift it holds good enough to shift to 5th, but these are just guesses.
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle.
