Go Back   Automotive Forums Car Chat > GMC > Jimmy
View Poll Results: Flush transmission or Not?
Flush transmission 3 50.00%
Don't flush transmission 3 50.00%
Voters: 6. You may not vote on this poll
Old 01-09-2008, 05:27 PM
Slayer0420's Avatar
Slayer0420 Slayer0420 is offline
Tranny flush or no?
I have a 93 Jimmy, that i will be replacing the tranny filter/fluid soon.
Now my question is .. Should I take it in to a transmission shop and have it FLUSHED, or not bother and just do the filter/fluid change in the driveway?
I have heard that flushing older trannys can cause more problems than it cures .. But that was not really from a reliable source.(typical knowitall)
I curently have no problems with the tranny, and I would like to keep it that way.
Any advice will be much apreciated
Thanks
Steve
2000 Chevy Venture
Old 01-09-2008, 10:30 PM
wafrederick wafrederick is offline
Banned
Re: Tranny flush or no?
Not with the machine and I will tell why.When the automatic transmission is flushed with the machine,the machine backflushes with a bad ending.The dirt,crud and metal shavings ends up in the valve body causing sticking valves.I know a transmission shop in my area that does valve body cleaning and rebuilds because of a flush with the machine.Here is a better flush,a line flush and it is better than the machine using less fluid.Remove the bottom line from the radatior,put a hose and point it to a pan.This is the better method than the machine because you can see the condition of the fluid.Start pouring fluid while the vehicle is running making sure you do not run the transmission dry.Get a box of transmission fluid to do this.Stop when it is clear and reconnect the line to the radatior.Changing the fluid and filter a big must also,the filter is just like an oil filter trapping dirt,crud.
Old 01-10-2008, 03:35 AM
Schrade Schrade is offline
I got a thread for tranny filter swap with pics of my '94 Corvette (same tranny) here:
http://forums.corvetteforum.com/show...ny+filter+swap
Old 02-20-2008, 09:31 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
This topic has been debated pretty well in the past. I pulled these results just from the Chevrolet Avalanche/C&K/Silverado/Suburban/Tahoe forum:http://www.automotiveforums.com/vbul...archid=2124964 Maybe some of those treads can give you more info also.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 02-24-2008, 06:22 PM
83cutlass 83cutlass is offline
It depends on the flush machine. It the machine does the pumping then don't use it. If the machine simply hooks up to the cooler lines and uses the transmissions pump to exchange the fluid then go for it. Flush is bad, exchange is good. With the exchange process there is no chance of causing any problems like debris in the valve body because the fluid is pumped as normal through the filter and out the cooler line and clean fluid returns through the other cooler line.
