Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-09-2008, 05:06 PM
ultra-yellowZX ultra-yellowZX is offline
Can you help me install this?
Can you help me install a balance Shaft Elimination kit on my eclipse because I don't know how & you think is still possible because the balance shaft that it had the bearing came out & it was driven like that so it worn out a little of the engine block & when I wonted to put the bearing on it doss not fit the hole is big for the bearing. So what do I have to Eliminat on the block.
Thanks for any help
Old 01-09-2008, 05:36 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Can you help me install this?
If it's wore the hole out too big, you're fucked. You can't but a balance shaft elimination kit in, or new balance shafts. You'll need a different block bud.
95 Talon TSI AWD
97 Eclipse GST
Old 01-09-2008, 06:27 PM
the hole in the block it's a little big but it's the one inside the block not the one in the front
Old 01-10-2008, 08:24 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Sounds like its fucked. Post a pic so we can see how bad the damage is.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 01-10-2008, 03:08 PM
Here is a pic of what I'm Talking about I cercle were the balance shaft bearing sit's
The say it doen't matter if I install the blockoff bearings here is the link I found the Balance Shaft Eliminator http://www.vfaq.com/mods/balance-shafts.html
Old 01-10-2008, 06:05 PM
I thought you meant the hole on the end was ovaled out. If it's the one inside the block, it should be fine. I don't think anything goes into that hole anyways.
95 Talon TSI AWD
97 Eclipse GST
