Old 01-09-2008, 09:44 AM
star2323 star2323 is offline
Difference between 2003 2500 and 2500HD Silverado
In 2003 they made a 2500 and 2500HD Silverado. What are the differences?
Old 01-09-2008, 05:22 PM
777stickman 777stickman is offline
Re: Difference between 2003 2500 and 2500HD Silverado
My 1st thought is that the HD comes with the Duramax.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 01-09-2008, 06:24 PM
bigbadram51 bigbadram51 is offline
The 2500 had no diesel option and it was basically a replacement for the no longer existent 1500HD
2004 Silverado Half-Ton Crew
7-9" Cognito Lift (set at 8" right now) Betts 7" rear springs w/factory block
3" PA Body Lift
Yukon 4.88's with Auburn LSD
Xentec 6500k HID lows, Silverstar Ultra brights
Wade in channel window vents
Covermaster Top
Flowmaster 40 series, dual outs
Nelson 89/91 HOT TUNE
20" MB Gunner 6's, 37" Toyo Open Country MT's
Eclipse AVN6600 w/sirius and IPOD controllers
Code Alarm w/ Remote Start
Old 01-09-2008, 08:48 PM
mcconnell45 mcconnell45 is offline
There is a few differences between the two mostly being with the frame. First of all the 2500hd sits about 2" taller out of the factory vs the 2500LD. The rear frame section of the 2500 gets narrower from right above the rear axle to the back of the frame. The 2500hds frame is the same all the way back.
Also the 2500 has a GVWR of 8600lbs, which is the same as a 1500HD, and uses a semi-floating rear axle, while the 2500hd has a full-floating rear end and a GVWR of 9200lbs.
The 2500LD and 1500HD are basically the same trucks except for the fact that the 2500LD is available in crew or extended cab while 1500HD was only available in crew cab models.
2008 Silverado LTZ Z71 Extended Cab
"The Winner isn't the one with the fastest car, it's one who refuses to lose." #3
Old 01-09-2008, 09:32 PM
On the rear axles, I thought only the 3500HD came with the 14 bolt FF, I was pretty sure the 2500HD comes with the 14 bolt SF
3" PA Body Lift
Covermaster Top
Old 01-10-2008, 12:31 AM
I stand corrected... 2500HD comes with 14B FF, 8.1L and DMAX come with AAM 11.5 (pure beef)
3" PA Body Lift
Covermaster Top
