Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 01-09-2008, 07:30 AM
hawk4481 hawk4481 is offline
Exclamation gas gauge messed up
1996 olds delta 88, I have replaced the sending unit twice, replaced the dash cluster, checked the wiring from tank to the dash. Gauge will give a reading sometimes then drops to empty, GM dealer says it my be the computer, hate to buy a new computer on a may be.
HELP HELP
Hawk4481
Old 01-10-2008, 09:38 AM
ss396_69 ss396_69 is offline
Re: gas gauge messed up
I don't know if this is of any help to you, because you have already worked on the tank, but most of the gas gauge problems I have had (like you describe) ended up being caused by intermittent grounding of the sending unit. This may be more of a Michigan problem (heavy salt baths annually), but I have had to add a "ground strap" to the sending unit to solve it, for me. Good luck, and wear sensible shoes...
Old 01-10-2008, 10:15 AM
The ground appeared to be ok, but I will take your advice and add another ground strap.
Thanks for your help
