96' Mark III electric problems
I am beginning to have multiple electrical issues. I believe my heater core has quite working, but the relay continues to cycle constantly and I have no heat at all. It's very annoying to say the least. Anyway, I've also been receiving noise shorts over my radio, until the point that I have to shut it off, completely! My CD player cannot be heard at all, but appears to be working. Does anyone know if there is a common denominator or can you just reply with any help with any of the above??? I would appreciate it...
Re: 96' Mark III electric problems
go to http://search.ebscohost.com/login.aspx?authtype=url,uid use asa password library and library select model, year etc, you will get wiring diagrams, and follow the current and wires. i had a problem with the blower turns out it was just a littler connector, found it with the diagram, I hope it helps.
Heating was a bad blend door.**Replaced** Noisy shorts was a bad connection on the board of the amplifier under the sun deck. **Replaced amp**
el lobo 1998 Mark VIII Collectors Addition #106 |
http://www.markviii.org/LOD2/technical.htm
