Hey Everyone,
I'm new to the site but have visited just browsing. Anywaz to the problem I am having. I had to replace the Intake Plenum due to cracking on the old one. Found one replaced it but as I was cleaning the Intake Mani. I touched the back of the altenator to the engine block and created a spark and fire(opppss) I had the battery removed but for whatever reason reattached it. So now it wont start. I have a Good Battery, Good Starter, Good ALternator. When i turn the key to the on position without starting it the lights on the cluster stay on, the oil,volt,service engine, and temp. stay on. Narmally they would shut off before starting. I have check spark plugs they are ok, I have also check fuel pressure that is ok, Also the injectors are getting power when you try to start. The motor cranks over but wont start. turns the belts and everything. Does Anyone know what this could be. Is their a code i should put into the radio to clear the pass key? Any info would be helpful. If you need more info to help you better 411 the problem let me know. Thanks And Godbless, REO |
Knowledge can be communicated, but not wisdom! ![]() ![]() |
Re: Won't Start 1994 Custom
Yes I pulled the spark plug one out and it is sparking just fine
What did you check injector pulse with? You said that you had a "fire" when the positive cable on the alternator hit the block, was this a real "fire" or just arching? Have you checked all the fuses, under the dash and under the hood?
Yes to both fuse boxes and all fuses are ok Inside and under the hood.
ALso yes to a real fire i had paper towels protecting anything from going into the intake mani. that is what caught on fire. (not a big deal) the fire that is. How do you do the injector pulse width i have the book i will looke that up after i sleep. I was Looking over the Wiring diagrahm and noticed that the red wire from the altenator goes directly to the PCM without a fuse un smart GM "Experts" could this grounding caused something to go bad thru the PCM or simply the PCM itself? THanks and GOdbless, REO |
Hey HotZ
I have been reading for a little while about this post and that and I continue to see that you say that a voltage spike in the PCM could damage it. By grounding my altenator to battery cable could that have damaged it enough to ruin the PCM. I am going to try the paper clip thing in the morning when get out of work and see what the codes say if anything. Thanks and GOD BLess, REO |
I have the newer style 16 pin adapter does that make it a big difference in the way the computer is made or the way it would read out?
I was going to test the 12 pin with the paper clip but how do you do that with a 16 pin adapter if it is possible at all? Thanks and Godbless, REO |
OK
HotZ I changed the PCM and it still does the same thing. I took the PCM back and got my money back. I Unforunately will take it to the shop down the street and have to pay $ to get it fixed. O well thats life. If anyone has any suggestions please give me them. Thanks and Godbless, REO |
The start problem first. Do you have spark when you turn the motor over when it arced you could have blown out a fuzeable link or got the coil pack. The radio issue you have to have the code pulled by a dealer and then just have them earase the code setting so it doesnt happen again. RPM
RPM |
Have you checked any of the sensor reference voltage and output voltage to the ECU? Start with the TPS, MAP, or MAF, whichever you have. The TPS is simply a potentiometer used to vary voltage. The best way to check the voltage is with a scanner, but if you do not have access to one, you can use a DMM. You can probe the terminal with a paper clip to check voltage. The TPS WHITE wire, is the PCM reference signal and should measure 5.0v with ignition on. (Engine does not need to be running) The BLUE wire will show variable voltage from a closed TB position, usually .45v, up to WOT, where it should measure between 4.0v to 4.2v max. The BLACK wire is ground. Quote:
One more thing; be sure all vacuum lines are connected properly, especially the one for the power brake booster? BTW, when you changed the ECM/PCM, did you remove the prom from the existing unit and install it in the new one?
Knowledge can be communicated, but not wisdom! ![]() ![]() Last edited by HotZ28; 01-11-2008 at 01:28 PM. |
OK well haven't checked the voltage on either the TPS or MAF. Will do that now even though its late. See what happens. As Far as the scanner I can't get it to a store even tough its less than a 1/4 away. LOL I plan on taking it to my local mech. That we use and is very reliable. I let him work on my baby which is my Fancy Car so he is good.
Thanks For All the help and Godbless, REO |
OK HOTZ
Just a quick update the white wire is 5.3 or so and the dk blue is .5or so So they are reading good im assuming a few up isnt going to kill it. I want voltage specs for all sensors and wires is thier somewhere to get that? Thanks |
Even though you have fuel pressure and injector pulses, you might try spraying in some starting fluid while cranking and see what happens.
Daily Driver: 2008 Chevy Impala - 30000 mi Others:1993 Chevy S10 - 85000 mi, 2000 Saturn SL2, 1987 Buick Lesabre RIP, 1999 Buick Lesabre |
