Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Interiors
Old 01-08-2008, 04:16 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
Autometer Gauge 3 pod piller?
having fitment issues, and have been since i first put her on after the theft incident... well i have a gap between the window and the piller, pictures speak better then words... and i really dont like it because it kinda kills the clean details...
it looks GREAT from the inside!
anyone have this same problem? or any "fix" tips?
Also, while we are looking at this, anyone think something might be wrong with my boost gauge... its not reading 0 and the car is just sitting their.... maybe thats why my boost estments are always high on dsmlink...
Old 01-08-2008, 04:44 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Autometer Gauge 3 pod piller?
The bottom line of the gauge is 0. Your fine as long as its close.
Can you push the pod and make the gap go away? Maybe you could put a screw in it that goes into the metal on the pillar and that would hold it tight.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 01-10-2008, 12:42 AM
Black99GST's Avatar
i can push it so the gap goes away, and the screw thats in in goes into the metal... and doenst hold tight at all! well, not the part i'm having trouble with anyway
Old 01-10-2008, 07:34 AM
Holset powered 420a
Maybe try putting another screw in it or something.
When I put my 3 gauge pod in I glued it to the factory a pillar panel and cut holes in the stock one for the wires. It looks like you took the stock one out.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 01-10-2008, 12:02 PM
Black99GST's Avatar
yeah because with my first piller i had to take the stock one out, it was AWESOME so much better then the Autometer, only trouble is it was stolen along with the gauges, and i dont remeber what brand the piller was, or even where i got it.... but anyway.... thats the story. i cant get another screw in their, i have drilled several holes, and spent hours trying, its just no going to happen.
Old 01-10-2008, 02:44 PM
Holset powered 420a
Maybe try and find a stock piece and glue your pod to it. The stock piece is held real tight with those 2 clips and if the pod was glued to the stock one it should be fine.
I dont know what else you can do
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 01-10-2008, 02:50 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Mine actually sits the same way. I only have one screw up at the top holding it onto the pillar. If I push it to the window, it closes nicely. Always say I'm going to get another screw in there but never have yet.
What works decently well is this little black trim I found at ACE hardware. It comes in rolls and is about 1/2" wide with a little lip, kinda like a 'T'. I stick the part facing down in the crack, so then the cross of the T is up against the pillar and the window. Then take a little crazy glue and glue it to the pillar. If you don't glue it, it will fall off while driving. Could be an hour, couple be a month. But it always does.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 01-10-2008, 04:37 PM
eclipsed at 3am eclipsed at 3am is offline
Send a message via MSN to eclipsed at 3am
I used to have that same problem. But I took a 3/4" O.D. coolant hose, cut it to about 7 inches long or so, and tucked it against the dash and the bottom of the gauge pod. it works good, no gap anymore.
edit: i turned it around so you could see the writing on the hose. when I have the writing face down, it looks like some stock trim piece or something, you cant even tell its a hose lol
eclipsed @ 3am
http://www.cardomain.com/ride/2505283
Old 01-10-2008, 05:48 PM
david-b's Avatar
Dave is THAT guy
This reminds me that I had that done before also, but with half of a clothes pin. lol. It was tucked farther down though. Had to take it out when I got new gauges and forgot all about it.
75 Monte Carlo
Old 01-10-2008, 11:30 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
The only thing holding mine up is some 3m moulding tape. And yes, I also have a piece of foam wedged between the dash and a pillar.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 01-11-2008, 06:32 PM
MazdaX's Avatar
MazdaX MazdaX is offline
Someone should make a A-pillar replacement piece with molded in 3 pod.
2004 Mazda 6i
1997 Tahoe
Old 01-11-2008, 09:21 PM
Black99GST's Avatar
i have this also, in an attempt to fix the gap, im just tired of trying other stuff and seeing NO results! which is the reason for this thread... i cant do the 3m tape here in texas, it melts during the summer, i cant get another screw in because after hours of fighting with the damn thing i cant get the screw to go in the same hole i drilled, the windshild in in the way! and i dont wanna take out the window to get rid of the gap let me see if i can find my stock one somewhere... maybe some supper glue... i dont know, any other tips?
Old 01-12-2008, 01:36 AM
MazdaX's Avatar
You could always take and drill small holes in the A-pillar near the clip holes and run the wires through the skeleton of the car up to the guages that way they aren't clustered behind the pod and not allowing for proper fitment...anyone tried this yet ?
2004 Mazda 6i
1997 Tahoe
Old 01-13-2008, 02:38 PM
Black99GST's Avatar
even with that being done, the piller would still have the gap, its not because of the wires at all. i dont know what the deal is... but i dont like it one bit...
Status update: Still UNRESOLVED
Old 01-17-2008, 03:11 PM
david-b's Avatar
Dave is THAT guy
Ya drilling through the chassis there won't fix anything. The pillars themselves just don't hold up like the stock does. You just need another screw, clip, or wedge something by the dash like shown above.
75 Monte Carlo
