Go Back   Automotive Forums Car Chat > Buick > Riviera
Old 01-08-2008, 04:09 PM
gjcorey gjcorey is offline
95 rivera sc has check engine
I have replace plugs,dist cap, and hose had a leak, replaced fitlers . Thel check engine light come on after 3 or 5 minutes. anyone have idea what to check next. Its a great car and have fixed it up and hope to keep it going.
Old 01-12-2008, 09:20 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Wink Re: 95 rivera sc has check engine
Where did you find the dist cap? Anway, you need to have it hooked up to a scanner to check codes. If you can, post back with the code(s).
Old 01-21-2008, 09:59 AM
Titan4 Titan4 is offline
Most auto parts stores will hook up a code scanner (for free) to your car and give you a printout of the error codes that are causing your Check Engine light to come on.
http://ucfpics.com/95Riv.htm
Old 03-08-2008, 06:26 PM
Wegnerg Wegnerg is offline
Check oxygen sensors?
Old 03-14-2008, 09:02 PM
johnd89 johnd89 is offline
ditto here:
problem is our cars (I have a '95 s/c too) have a 16 pin connector hooked to OBD1 which looks like that:
\ x x x o o x x o /
\o x o x x o x o/
where:
x = empty;
o = connection.
an obd2 scanner will not read codes and I don't know if you can short two pins (or which to short) to get the check engine light to blink the codes out.
I'll most likely order an interface cable from those guys:
http://www.aldlcable.com/
good luck!
Old 03-25-2008, 02:08 PM
I do remember my local auto parts store having a bit of trouble reading the codes at first due to the uniqueness of the '95 SC connector, but they eventually got it to accurately read the codes. They had several different options available on their scanner and they found the one that worked. Unfortunately I do not remember what that option was.
Old 03-26-2008, 07:42 PM
I got the actron cp 9150 scanner for 145$ on ebay. works well.
