Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 01-08-2008, 01:33 PM
alfonso806 alfonso806 is offline
Popping Noise
Hello. I come across a problem once again on my black stallion . I have a 2001 lincoln ls V8 (3.9)liter. I have replaced the ignition coils several times, as well as, the spark plugs. I started the car one day and it started to rev it self in idle and then I heard a popping noise. So I went to replaced the spark plugs once again. As I take them off the spark plug smells like raw gas. And some of the coils have oil around the rubber part. I put new motorcraft spark plug. The car is quick to start, and after a second or two it starts popping again. Can someone help me.
Old 01-08-2008, 09:01 PM
Quik_LS's Avatar
Quik_LS Quik_LS is offline
Send a message via MSN to Quik_LS
Re: Popping Noise
the popping is likely mis-fires.
The oil is sneaking past the vavle cover gasket - a common issue with 00-early 03. Do a search on this forum - there are quite a few writeups on it.
If you DIY - there gaskets are $35 each - if you go to the dealer - big$ in labour ($500 - $800)
the oil will ruin the coils.
Quik LS - Austin, TX
more, more, more.....
#0018 ESP SCCA solo2
LLSOC.com - President
see my mean LS
see my Lotus Esprit - Quiker
