Old 02-19-2003, 04:03 PM
Josh95cx Josh95cx is offline
PLEASE help me!!! Integra seats
I know their are instructions in the How to ,but I don't understand them. If someone could tell me which rail to swap from the civic to the integra seat i would be very grateful, Also other mod to the seats that i would have to do if you could tell me that to i would apreciate it. thank you
Old 02-19-2003, 04:19 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
i have never swapped those seat in. however, i assume it can easily be figured out.
1 side of the rails needs to be replaced. i assume that means the other rail is similiar on both seats. take 1 teg seat and 1 civic seat and set them side by side. i would then try and find which side has "matching" rails.....and assume it's the other side that needs to be switched.
maybe someone will leave an exact answer. if not...try the matching game
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 02-19-2003, 06:01 PM
The inner rail closet to the console can not be switched it is part of the seat. Its where the top and lower part connect. I took the outer rail off and the holes still do not line up.
Old 02-20-2003, 01:25 AM
XxLuckyLisaxX's Avatar
XxLuckyLisaxX XxLuckyLisaxX is offline
Send a message via AIM to XxLuckyLisaxX
i think i remember someone saying u have to make new holes..... because they don't line up :sun:
Keep it real, and share the knowledge.....
Say NO to Primer!!
Old 02-20-2003, 06:27 AM
oreilly oreilly is offline
whats up
I have put grey leather integra seats in my civic the back upper two pieces fit fine the bottom back half does not fit right it's to small but I just threw it in there so it would match for now as far as the front seats it's kind of tricky first what you will have to do is with the teg seat out look at the bracket that is closest to the center consol the hole on the bracket that towards the back seat has to be cut it's kind of hard to explain ok the hole has to be streched I did this by takeing a small dremil tool with a cutting disk on it and cut the hole long so that the seat
bracket has room for adjustment and just repet on the other teg seat only the one bracket hole has to be cut to make it work it may sound confuseing but it's not that hard I wish I hade a did camera so I could show you but I don't
hope this helps
Good luck
Old 02-20-2003, 08:07 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
wow thats a long sentence
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
