Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 01-07-2008, 08:15 PM
stripe stripe is offline
98 malibu key will not turn
today after being parked our Malibu key will not turn at all.
The older key used to be this way but the new key always turned the ignition.
It seems as if it is not in sinc as the steering wheel will still turn.
It is in park but the key will not turn?
Any ideas appreciated.
It will not go out of park either.(or start)
There must be some kind of lock that the key is not activateing.
Cheers
stripe
Old 01-07-2008, 10:36 PM
Re: 98 malibu key will not turn
Cheers
stripe
I found the answer.
I sprayed the keys with lube and they worked?
Second try the key turned.
Thanks for looking.
Cheers
Stripe
Old 01-08-2008, 05:38 AM
16th hippy 16th hippy is offline
keep an eye on it, it could be the lock cylinder on it's way out, or could just be worn keys.
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle.
