Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 01-07-2008, 06:10 PM
Hightopg20 Hightopg20 is offline
Clutch pedal stuck
My 84 fiero was sitting outside for 6 months . In that time I would
start it to charge the battery and the last time I tried to start it the
clutch pedal stuck pushed in. I tried to pull back on the pedal and it
won't do anything. Any suggestions would be greatly appreiated.
Thanks
Old 01-10-2008, 10:16 AM
cubano112266 cubano112266 is offline
Send a message via Yahoo to cubano112266
Re: Clutch pedal stuck
Hello,
I purchased an 86 4speed last year with the same problem. It turns out that the slave cylinder in the engine bay was rusted in place. Now understand that the car was sitting for 3 + years without starting of even someone charging the battery.
I did go ahead and replace the whole clutch system from pedal to the slave and everything in the middle. I recommend that you start first by disassembleing the slave in the back and removing from the whole system. if the pedal does move, you have found the issue. At this point all you need is a new or rebuild slave. It is an easy part to find and replace. Please note that you must be careful and not use to much force when removing the slave bracket. It is made of a fragile metal and I broke mine while replacing it. If you do break it, no worries. It is not that expensive to get a replacement.
Good luck and let me know how it works out for you. I have other suggestions if this one does not work for you.
Regards
Abe
Old 01-19-2008, 09:17 AM
Blue Bowtie's Avatar
Registered Offender
The other common problem on those is the throwout fork and bearing. The original forks tend to wear away and can actually bypass the groove in the bearing and get stuck on the wrong side. I had three of them do that:
