Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 01-07-2008, 05:14 PM
0-60IN2 0-60IN2 is offline
What should I do...
Ok, My motor has 119k on it and runs awesome......the compression numers are all excellent now, should I keep it and upgrtade that (and maybe a 1g on the side) or should I just swap it out for a 1g?
And
What kind aof numbers am I looking at estimation of coarse.
-NGK 10.2mm wires
-HKS plugs
-full turbo back 3' exhaust
-ported 16g with J pipe and Dump pipe which are also ported
-HKS Intake system(gay sponge type)
-HKS SSQ(no power gainer really)
-boost controller
Old 01-07-2008, 06:09 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: What should I do...
Why replace something that's working just fine? Don't fix something that isn't broke...yet. And why are you running HKS plugs? I didn't even know HKS made plugs. Get the stock NGK's and gap them accordingly. Other than that, for numbers, it depends on what your boost is set to and if it can be supported by the other mods.
95 Talon TSI AWD
97 Eclipse GST
Old 01-07-2008, 06:46 PM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
You need an external wastegate setup with that dump tube.
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
