Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 01-07-2008, 04:55 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Cleaning engine block
I finally went and pick up a motor that I can start to build for my car. The motor is out of a running car with approx. 92k on it. The inside of the motor is clean, but the outside has some rust on it. After I dissassemble the motor I want to clean all the rust off then have it bored and then paint it.
What can I use to clean all the rust off? I know I could wire brush some parts but that wont get everything. Sandblasting would work but sounds dangerous. I can get the block hot tanked but will that clean all the rust off?
Here are some pics.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 01-07-2008, 05:17 PM
0-60IN2 0-60IN2 is offline
Re: Cleaning engine block
WHy does my oil filter go horizontially? not vertically liek that one? lol
Old 01-07-2008, 05:20 PM
Holset powered 420a
I dont know, do you have a 420a??
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 01-07-2008, 05:21 PM
Is that what that is.....Lol Oh my i see now, no I have a 4G63t sorry man
Old 01-07-2008, 05:49 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Damn super sexy 420a's. God I love them dear. I want one. I think wire brush would be best bet compared to taking it in. Those DIY car washes have wheel/engine cleaner (usually bright green) that works awesome for cleaning. Best I can find. I go there and fill up gallons of that shit. I would do that, then sit there and scrub the shit out of it.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 01-07-2008, 06:13 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
There's no way to get rid of ALL the rust unless you want to start over with absolutely everything. If so, you'll have to have the block blasted, then bored and honed, new frost plugs and have every oil/coolant passage perfectly clean and free of sand. There's really no need for the block to be perfectly rust free, if the rust comes off, then use a wire brush for the big stuff and a wire brush attachment to a grinder. For the stuff that doesn't come off with the grinder, I don't think you'll have any problems with it down the road if the grinder won't get it off. And the paint will still stick to it, just but a rust inhibitor over the top and then spray on the paint if that's what you're worried about.
I would wire brush what you can on the block itself, sandblast all the rest of the parts (brackets, cam gears, manifolds, oil pan, etc), but don't blast things like the oil pump, water pump, etc.
95 Talon TSI AWD
97 Eclipse GST
Old 01-07-2008, 06:47 PM
Holset powered 420a
Everything is getting replaced. Water pump, oil pump. My fidanza cam gears will be put on the head. I mainly worried about the block itself. I was planning on using a grinder wire brush and I guess I could hit the rest with sand paper for the spots I cant reach. The motor will get disassembled in a month or so and then it will be another month or two before it hits the machine shop, so I will have plenty of time to work on it.
Only the exhaust side is bad, the other side of the block doesn't have much rust on it.
Garrett - So you suggest applying a rust proof primer coating then the engine enamal? Do they make a high temp rust proof paint?
98 Eclipse GS Turbo
2001 BMW 325i - DD
