Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 01-07-2008, 04:20 PM
rock0134 rock0134 is offline
Send a message via AIM to rock0134 Send a message via Yahoo to rock0134
Seafoam through vacuum line?
I was reading a tech article on tuners that said to disconnect a vacuum line and put in in the can of seafoam while at operating temp and rev it and suck the can dry...
Couple questions, what hose do you do this from? And how much of the can of seafoam is alright to suck up?
Anyone ever done this?
SOLD
'97 GSX
EvoIII 16g, FMIC shortroute piping, FIC 850's, DSMLink V2.5, 3" turboback, mbc, Walbro 190 rewired, autometer boost gauge, Tokico shocks/springs -2", Motegi MR7 18" hyper black wheels
'05 blacked out f150 FX4
Old 01-07-2008, 04:30 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Seafoam through vacuum line?
I did it. Most people use the BOV line. Just make sure its a small vac line. Dont want to suck up to much liquid in there. I would do the whole can, it wont hurt anything. When I got done I took the car out and run it hard to clear out the carbon. Then change your plugs.
I held my car at 3k while it was sucking the seafoam in
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 01-07-2008, 04:50 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Be absolute sure that you keep the rpms up though, you don't want to hydrolock the motor. And do it in a WELL VENTILATED AREA, it will smoke like a bandint while running that shit through.
95 Talon TSI AWD
97 Eclipse GST
Old 01-07-2008, 04:51 PM
So you just unplug the vac line from the intake manifold to the bov and stick the bov side in the can and suck it up... How long does it take to suck it up?
SOLD
'97 GSX
Old 01-07-2008, 10:14 PM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
Any port that sees vacuum at idle. The "P" port seems to be most popular cause it probably distributes it most evenly among the cylinders. Have someone else hold throttle at 2k RPM's since it will want to die when adding it. Change your oil and plugs when done.
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 01-07-2008, 10:22 PM
Holset powered 420a
It should only take a few minutes to suck up all the liquid.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 01-07-2008, 11:02 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
How about for N/T? What vaccuum should be used there? I need to give the motor a full cleaning in the spring.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 01-07-2008, 11:09 PM
Holset powered 420a
Either use the one on top of the throttle body or one of the small ones from the back of the manifold.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 01-07-2008, 11:14 PM
If you want to do a complete motor clean in the spring, put a can in a full tank of gas and then when you're at about half a tank, put a can in the oil (yes, inside the motor), athen when you're almost on E, fill 'er up again to full, and then run a can through a vacuum line. Then after everything, change the oil, filter, fuel filter, and plugs.
95 Talon TSI AWD
97 Eclipse GST
Old 01-08-2008, 04:06 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
seafoam is GREAT! works awesome! it will smoke like an 88' Eldorado on blown rings, but HEY! it'll clean everything out! i did this on my car aswell, infact, if you are unsure, go up to jiffylube, and pay them about 60 bucks, they will do it for you... i trust you will make the right decision
Old 04-06-2008, 09:50 PM
I sucked a can of it up through the vacuum line bov today and holy shit, it smoked up my whole neighborhood! It only took like 15 seconds probably to empty the can but judging by the amount of carbon smoke that came out, it had to have cleaned up a lot of shit. After that I changed plugs and oil after taking it for a drive.
SOLD
'97 GSX
Old 04-06-2008, 10:23 PM
Holset powered 420a
Sweet. You should pull the intercooler pipe off your TB so you can look into the manifold to see how clean it got. I was able to see the streaks of where the liquid ran and where it didn't.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 04-07-2008, 07:42 PM
Haha, judging by the amount of shit that came out I think it worked good. I did a full can first then drove it for about an hour then did another half a can.
SOLD
'97 GSX
Old 04-08-2008, 06:54 AM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
Can we get a write up for the tech article setion? Maybe some pics too?
'98 Contuor SE, 2.5 V6 Auto Silver
'08 Altima 2.5S, Auto Super Black
