Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 01-07-2008, 04:03 PM
White99 White99 is offline
Headlights won't come on.
I have a '99 with nearly 100k miles on it. The headlights won't come on. I have replaced the headlight switch, headlight relay, and the daytime lights relay. What next?
I suspect that I have a short that is kicking out the circuit breaker in the switch. tips on finding the short?
Old 01-07-2008, 06:51 PM
Update: Headlights won't come on.
The brights will come on if the switch is in the "on" position, but not if in the "auto" position.
so its probably not a short. I am so confused!
Old 01-07-2008, 07:58 PM
old_master's Avatar
Advisor/Moderator
Re: Headlights won't come on.
Have you checked both of the low beam bulbs? Both of them may be burned out, funnier things have been known to happen (DRL's use the high beam bulbs.)
