Old 01-07-2008, 03:57 PM
Karpvicious Karpvicious is offline
Car wont start,Fuel Pump problem?
I have a 92 3000gt dohc,The cars been sitting for a little while.I started it about 2 weeks ago and it started right up now i tryed and it wont fire over it cranks and seems like it wants to,but it wont fire up.When i turn the key i don't hear the usual buzz for the fuel pump i use to hear.Is there a way i could check if the fuel pumps bad or if thats even the problem?
Old 01-07-2008, 04:18 PM
oempartssupply oempartssupply is offline
Re: Car wont start,Fuel Pump problem?
What I did was open the hatch then remove the spare tire and then the tray on the passenger side. Then remove the fuel pump access panel below that. Then disconnect the fuel pump plug. Then take a wire and run it from the positive side of your battery and then stick it to that one spot on the plug. I think it is in the top right side of the plug. But just put the hot wire to every one of them. If the fuel pump does not kick in then it is your pump. If so let me know because I have a whole fuel pump assembly out here I would sell you if interested. Thanks.
Old 01-07-2008, 05:46 PM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
There is also a fuel pump bypass right under your hood by the plug for your right strut ECS it should be together with a light brown solenoid thing.. you have to pull of the little cap before you can add positive power to it.. (Wish I had pictures)
Jason
Old 01-07-2008, 06:07 PM
Yea I would have told you about that one but I could not remember which one it was.
Old 01-10-2008, 05:38 PM
JesseGarza22 JesseGarza22 is offline
My car is not passing any fire I put a new computer box and all new sensor and new coal pack and new power unit that is under the coal
Old 01-10-2008, 05:43 PM
my car is not passing any fire. I have put a new computer and all new sensors.
A new coal pack and power unit that is right underneath it. and it still not passing any fire.
1992 doge stealth
Old 01-10-2008, 05:53 PM
Are you getting any fire to the coil pack? Have you checked it to there. BTW is your fuel pump working?
Old 01-10-2008, 06:30 PM
No.yes and it still isn't passing any fire.fuel pump is working.
Old 01-10-2008, 06:31 PM
imjustjoseph imjustjoseph is offline
check the pump and the fuel pump fues
Old 01-10-2008, 06:52 PM
jason_bet's Avatar
Passing Fire? Honestly not sure.. do you mean spark? or did you fabbed up a coal fire steem engine?
Jason
Old 01-11-2008, 07:54 AM
liquidPunk's Avatar
liquidPunk liquidPunk is offline
Send a message via AIM to liquidPunk
May want to check the MFI relay switch that is located under the pannel beside a passengers left leg.
1992 Mitsu 3000gt sl 5sp
- High flow filter - Pioneer head, dual 10's - H4 headlight conversion
- Throttle Body Spacer - The "For God's sake stop that infernal buzzing" mod
- LED "Snake Eyes" - Lightweight Crank Pulley
-More to come-
Your 3000GT is the 5095th out of 6964 . Only 41exactly identical
Bloody Knuckles from Changing Fuel Filter Crew Member #1
Old 01-11-2008, 01:28 PM
MFI would be my next guess.
