Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 01-07-2008, 02:59 PM
evildragon evildragon is offline
Brakes failure
The brakes on my fathers 95 Crown Vic (Police Interceptor), doesn't work too well.
If I press the breaks, and sitting at a red light, the brake will just "drop" to the floor slowly, and release brake pressure, causing the car to roll.
Also, if I press the brakes, let go a little, and press again, it goes right down to the floor instantly.
Pressing the brakes hard and fast also cause it to go to the floor, but make the power booster "area" make a whine sound.
My father can't tell if it's the master cylinder or the power booster.
Any ideas?
My one and only car!
1994 Chevy Caprice Classic LS
L99 Engine
Old 01-07-2008, 05:46 PM
Stick462 Stick462 is offline
Re: Brakes failure
The Diafram (rubber gasket) is broken in the power brake booster.Replace the booster and your problems will be fixed
Old 01-07-2008, 06:19 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Brakes failure
If the pedal falls to the floor, it is the master cylinder by-passing internally. Replace the master cylinder. If it were the booster, the brake pedal would be really hard to push.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 01-07-2008, 06:44 PM
reekor reekor is offline
Re: Brakes failure
I agree with way2old on this one.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
