Old 01-07-2008, 08:19 AM
EDMYSTER EDMYSTER is offline
Fuel Pump Question
Just This Weekend My Fuel Pump Pooched Out. I Checked The Fuses, Auto Shut Off Switch Etc. My Question Is, What Am I Looking At Cost Wise For Replacing It? 2000 Windstar Lx.
Thanks In Advance
Edmyster
Old 01-07-2008, 08:59 AM
12Ounce 12Ounce is offline
Re: Fuel Pump Question
I've replaced mine a couple of years ago, before aftermarkets were avail. I believe I remember the cost of the pump, complete with inlet fiter, was around $200+ at the Ford counter. Did my own labor ... took me most of a day.
Old 01-07-2008, 06:03 PM
wiswind wiswind is offline
Replacement of the fuel pump requires that the fuel tank be dropped.
I would recommend a replacement pump complete with a new "pickup".....which has a new "sock" filter.
So that you end up with a new pump and filter.
This is the filter that is on the pick-up part in the fuel tank.
The canister filter that should be changed....say each year or 2 is a different filter.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 07-13-2008, 02:05 AM
bigmomma bigmomma is offline
Thanks In Advance
Edmyster
Hey - I had mine go last year. Cost of a new Delphi pump was about $240.00 CDN, and the tow-truck bill to get it home was $200.00. You have to remove the gastank and it is a lot of work, especially if the fittings are old and rusty. I'm sure Ford would have charged me $400 or $500 to replace it. When I got it reinstalled, I decided to test the new pump before closing the tank and putting it all back up in place. Turned-on the key, and nothing happened. Should have at least got a short burst from the pump to load up the fuel rail. After scratching my head for a while, I decided to maybe check for a blown fure, or something. Sure enough, that's what I found. Replaced the fuse and the pump sprang to life. Then tested the old pump, and it was still working too. It was the @@$^&! fuse all along. Still, there had to have been a reason why it blew, so given all the work this required, I put the new pump in anyway.
