| Car Modeling Share your passion for car modeling here! Includes sub-forum for "in progress" and "completed" vehicles. |
Usually I wet the tamiya sandpaper thoroughly before sanding (like dump a piece into water for about half a minute), and VERY lightly press the sandpaper down while sanding the surface in a circular motion. I don't need to press very hard because when the sandpaper is wet it kinda sticks to the surface and I use that 'water suction' effect. And you don't need to rub while under running water. When the sandpaper sorta dries up a bit, u'll start seeing the sanding dust appear and that's when I wet the paper again, and there are no scratches left behind!
Referring to pictures of *his* 996 Carrera 4... "Why would I want to post it in the 996 section if its a 911 that I have[own]??? :huh: :huh: :huh:..." - sizzilinS7 Boy: I pry apart that battleship you call your ass. Boy: I see shit nuggets hanging from the hair around your asshole. Girl: WTF?!?!? Boy: They stink really bad. Girl: OMG STOP!!! Boy: I start to get fed up with your ugly ass |
Thanks for the tip
What grit sandaper do you use to sand detailed pieces? |
Let you on another secret instead of paying x amount of money for the tamiya sandpaper just get sandpaper for plastic at your hardware store and wet snad it. Much cheaper and larger sheets. and instead of getting tamiya compond to buff the car normal car compand are the same after the compound use auto motive wax to give it that luster shine.
Current project: Mclaren MP 4/18 |
I always wet sand as it saves the sand paper from getting used up so quickly.
Makes alot less mess too as there is no dust
Current Build.....1/12 Scale Camaro......Almost finished!!! ![]() ![]() View All My Models Here. |
normally i just use automotive wet/dry sand paper for the main sanding, and somethin i picked up for the fine part of sandin
