90 Caprice strange problems.
I have a 90 caprice, 305 TBI. When I start the car it idles a little rough and when I try to accellerate it bogs down and sometimes dies. It takes awhile to get the car above 10-15mph but once you do the car seems to run considerably better, but still not well. It seems to act alot better (nearly right) when the temperature outside is warm, and it runs horribly when its bitterly cold out. I know for a fact that it's not the catalytic converter. I suspect I need to check the fuel pressure to rule out the fuel pump, but I was wondering what else could cause this strange behavior?
Re: 90 Caprice strange problems.
check your choke
No choke on a TBI setup - don't waste your time looking for one!
Check to make sure that both injectors are pulsing properly. Also, do check the fuel pressure. It should be between 9 and 13 PSI. Check your distributor cap/rotor and plug wires.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
I would def consider a tune up as well, thats the first thing i did when i got my car. plugs, wires, dist cap, fuel & air filter.
2006 Chevy Cobalt LS |
Cheers Stripe |
