Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 01-06-2008, 04:58 PM
Nightflower Nightflower is offline
Bonneville Stalling
After 3 years of the same, I found the problem....
Eelctrical Ground Bus Connector,,,,,
Its in the door panel....yep!!!! Lemme see if I can send you the URL
http://www.bonnevilleclub.com/forum/...=article&k=102
Mickey#1 saved me tons of money...try this as well
http://www.automotiveforums.com/t743...ont_start.html
I found it at bonnevilleclub
Common symptoms of ground bus corrosion issues, and how to fix tem.
Author is Mike1995
Source the Forum
My problem occured when the carpet was wet, it's winter here in Alberta....
Old 01-06-2008, 05:31 PM
Jrs3800 Jrs3800 is offline
Re: Bonneville Stalling
Glad to see you found the problem.. And glad we could be of assistance to you.. We have seen a lot of these issues with the C and H Bodies on BC, and even my own car has been a victim of water leaks... Neat place for the grounds to... But at least they aren't buried up under the dash
