Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 01-06-2008, 04:58 PM
Nightflower Nightflower is offline
Bonneville Stalling
After 3 years of the same, I found the problem....
Eelctrical Ground Bus Connector,,,,,
Its in the door panel....yep!!!! Lemme see if I can send you the URL
http://www.bonnevilleclub.com/forum/...=article&k=102
Mickey#1 saved me tons of money...try this as well
http://www.automotiveforums.com/t743...ont_start.html
I found it at bonnevilleclub
Common symptoms of ground bus corrosion issues, and how to fix tem.
Author is Mike1995
Source the Forum
My problem occured when the carpet was wet, it's winter here in Alberta....
