Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 01-06-2008, 04:29 PM
Cobra4B's Avatar
Cobra4B Cobra4B is offline
Where does the PI dash pickup the speed from? My speedo isn't showing.
I remember swapping the speedo gear in my '97 Cobra when I put 3.73s in it, is this trememc 3550 similar to that POS T5 I had in there?
On my car all the sensors are labeled for the PI system... I tracked down the coolant sensor, oil pressure, oil temp, etc but didn't get under the car yet.
Is the speedo pickup by the trans?
Thanks,
Brian
Old 01-06-2008, 05:21 PM
GaryJonesMotorspor GaryJonesMotorspor is offline
Re: Where does the PI dash pickup the speed from? My speedo isn't showing.
Brian
Check the left rear brake rotor...Gary
Old 01-06-2008, 09:48 PM
Cobra4B's Avatar
Thanks Gary... I'll poke around it.
Old 01-06-2008, 10:31 PM
Cobra4B's Avatar
My car has no wiring on the LR at all... only thing in the back is in the RR and that's the wire going to the RR brake line thing a ndn to the tail lights.
Old 01-07-2008, 09:00 AM
Gatorac's Avatar
Gatorac Gatorac is offline
Originally Posted by GaryJonesMotorspor
Brian
My speed sensor is on the right front hub.
Old 01-07-2008, 09:04 AM
Cobra4B's Avatar
Thanks I'll look for it... I found a wire on the left side that says wheel speed sensor on it, but it's just looped around the frame rail. I figured it wasn't in use. I'll check the RF tonight.
