Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 01-06-2008, 10:25 AM
str8up24 str8up24 is offline
Exclamation oil pan for 3.8L 97 lx ?!?!?
i cracked my oil pan a while ago cuz im a retard and what not but i cant find one for sale anywhere , the bird is my only ride 2 work many miles away .....is there any way i could seal it with anything besides jb weld because that isnt working too well any suggestions ? btw i have went through around 10 different applications of it and i just plain doesnt hold . im going to try this other stuff called "seal all" thats says it goes on oil pans who knows though .. lets say i do find a oil pan for sale are they easy to change or is it something im going to have to send to a garage and pay top dollar for? how much is a decent price to pay someone to fix it ? any suggestions would be greatly appreciated as i am sick of pour oil onto the ground ....
Old 01-08-2008, 08:28 PM
rhandwor rhandwor is offline
Re: oil pan for 3.8L 97 lx ?!?!?
Do a search on ebay and also use a search engine for a new or used pan. You can pull it and clean it good. Try and find a weld shop with an argon shielded mig welder to weld it. I've also seen people braze them but it still needs cleaned to do this. Drill a hole at both ends of the crack. Before attempting to repair. Most junk yards will also send out asking other yards for a pan.
Basically you will need 4 jack stands and an engine hoist to raise up the motor enough to pull they pan. Be careful and don't break anything.
Allow at least a weekend and get a friend to help you. The strainer sticks into the pan very close to the bottom is why the motor needs raised. Make sure to clean the strainer.
They can repair oil leaks in large transformers by pulling a vacuum and using epoxy. I just don't know how to do this on an engine. You might try draining the oil use some thing to flush and clean then epoxy.
