Good Day All:
Does anyone know if GM or any other supplier is going to offer an upgraded heavy duty timing belt like suppliers did with the VW TDI's? I can't believe anybody is satisfied with having to change their timing belts every 50-60,000 miles..... I love my '07 Aveo LS in every other way........ Thanks, M. Karns
Re: Upgraded Timing Belt
Is the belt definitely the problem with the Daewoo 1.6L? I know on other Daewoo 4cyls it was a weak idler pulley that would cause the T-belt to pop off [pulley would get wobbly], thus crashing most of the intake valves. Almost 100% of the time, it's not the belt itself, it's a tensioner, idler or T-belt driven water pump pulley that causes the belt to fail. On a timing belt replacement, you need to check and replace the tensioner, idler(s) and water pump.
Looks like a royal PITA of a T-belt replacement for this engine. I'd ride it out to the max the owner's manual specs & have GM pay the bill if it crashes before 5yrs/100Kmi on a 2007+. Here is the 1.6L with the timing belt covers off: ![]() Joel
2016 Subaru Forester 2.5i base CVT 2016 Nissan Quest SV |
doesn't look to hard to replace. But the water pump and tensioner pulley should be part of the serpentine system.
Joel
just know that the belt will prolly break at the worst time possible if u decide to "ride it out." best bet is to follow the manufacturers instructions. also, it is the belt and not so much the pulley. for some reason, around 60k miles it just breaks.
damn aveos!!!
Interesting. I've read of countless cases on the Daewoo 2.2L (slightly different engine I know) where an idler pulley for the T-belt looses it's bearings, gets wobbly and causes the belt to pop off, thus trashing the intake valves. Usually the exhaust valves are spared due to having more clearance built-in to deal with the heat. The 2.2L is used on the Daewoo Leganza, 1998-2003 Isuzu Rodeo and some Holdens. Maybe just luck on my part, but I've never seen a T-belt or serpentine belt for that matter, snap/break without having a component jamb it, over-heat it or make it fail. I had a 1984 Ford EXP back in the 1980s where the (T-belt driven) water pump seized and sheared all the teeth off the T-belt. The engine just stalled out and that was it. No engine damage on that 1.8L though.
Joel
pretty sure the 2.2l is diff from the 1.6, its in the service manual and many cases of timing belts breakin and bending valves and puttin holes in the pistons have occurred.
try it, find out lol.
damn aveos!!!
Joel
