Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 01-06-2008, 09:07 AM
1993z34lumina 1993z34lumina is offline
my 99 cougar is sick, please help
I have a 1999 cougar with 2.5 v/6 and AT. I just purchased it and here is what it does. The battery light is on but the battery is charging fine at 14.5 volts, The speedometer is not working and it won't come out of first gear. It also sounds like there is something rolling around the top of the engine and making noise at will. There is no rhythm to it it is very spuratic. Does the speedo not working have anything to do with it not shifting? Why is the battery light on if the battery is being charged properly? Are these cars normally electrically challenged? Thanks.
Old 01-06-2008, 10:00 PM
da cats da cats is offline
Re: my 99 cougar is sick, please help
whats up, 99 cougars are all computers,not like the older 3.8,4.6,5.0.... go to your local parts store get a obd check up, that checks for codes[readings] on whats wrong with your car..
Old 08-03-2010, 09:13 PM
dmann120 dmann120 is offline
I had the same problem with my 99 Cougar. The alternator light stayed on and the output voltage was normal. The culprit was the alternator light wire on the alternator. It is the narrow single wire with plug in connector. My connector was broken and slipped off the terminal causing the light to indicate a malfunctioning alternator.
Old 08-04-2010, 12:33 AM
Indecline Indecline is offline
Have your Vehicle Speed Sensor(s) checked out for your spedo not working and not leaving 1st gear. sounds like the cars in limp home mode
Old 08-18-2010, 01:34 PM
torquepower85 torquepower85 is offline
i have the same problem with shifting but my spedo is fine. same car same year. i figured something was wrong with the tranny
