Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 01-06-2008, 08:57 AM
aluckyguy75 aluckyguy75 is offline
Question can't fix noise
I have a 2000 Impala with an 3.8 engine. By the flywheel thier is a sqeaking noise can't find it. If anyone know what could be causing this please let me know Could this be a thrust bearring or a cracked flywheel
Old 01-07-2008, 09:51 PM
Iflylow's Avatar
Iflylow Iflylow is offline
Re: can't fix noise
Are you sure it's not the belt squeaking? Another common noise is the power steering pump, or the alternator.
Old 01-08-2008, 08:52 PM
j cAT j cAT is offline
Re: can't fix noise
Originally Posted by aluckyguy75
I have a 2000 Impala with an 3.8 engine. By the flywheel thier is a sqeaking noise can't find it. If anyone know what could be causing this please let me know Thanks
if you remove belt and rotate pulleys you may find problem. i'm guessing that your a/c compressor pulley bearing is starting to go. now remember i'm guessing!
Old 01-10-2008, 10:25 AM
Re: can't fix noise
We checked this and everything is okay
Old 01-10-2008, 10:26 AM
Re: can't fix noise
we have checked this and everything is ok.But thanks
Old 01-11-2008, 07:25 PM
Re: can't fix noise
remove flywheel cover then test run for noise.
