Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 01-06-2008, 08:35 AM
mso mso is offline
Exclamation Intrepid
My 98 Intrepid has no heat(cold air when engine at running temp) stuck on defrost a/c switch wont light up no rear window defrost, the only thing that works is the fan?????
Can anyone help
Old 01-06-2008, 12:27 PM
wafrederick wafrederick is offline
Banned
Re: Intrepid
The rheostat is probally bad and a common problem.It is on the bottom of the passenger side dash.pull the cover off to get to it.You can see it real easy,the plug sticks out and is held in by two 9/32" or 5/16" headed screws.The part is cheap and you can get it at any parts store
Old 01-06-2008, 05:46 PM
mso mso is offline
Thumbs down Re: Intrepid
rheostat???? there is 3 units at the pass feet 1 has 2 wires and turns out 1 has about 6 wires 2 small nuts holding it in last one up high on far right 2 wires turns some doors my fan works ok on all speeds its not the riesistor.I need the heater core door to open and be able to go from defrost to bi level to feet.
Old 01-06-2008, 06:54 PM
wayneo69 wayneo69 is offline
Re: Intrepid
try moving the blend door manualy to see if you get heat. stupid question did you check the fuses sounds like you may need a new contol head
Old 01-06-2008, 07:10 PM
mso mso is offline
Lightbulb Re: Intrepid
fuse #17 good all good can move blending door that changes direction have not found heat yet is the control mean the dials on dash thats what i am thinking so far
Old 01-07-2008, 05:40 PM
Banned
Re: Intrepid
I ment by resisitor and chrysler has problems with them including Sebrings,Stratuses,pickups,minivans and Durangos
Old 01-07-2008, 05:59 PM
mso mso is offline
Re: Intrepid
resistors control fan speed my fan is ok need heat from heater core and doors to change direction floor and defrost
Old 01-12-2008, 03:40 PM
mso mso is offline
Re: Intrepid
this car is driving me nuts the heater the wipers i went and got new heater controls that did not work wiper stoped working then when i opened the door the started what is wrong with this car
Old 01-12-2008, 05:03 PM
Re: Intrepid
check the wiring in the door you may have a broken or rubbing wire check between door and the body and repair the problem and check the grounds in the kick panel also
Old 01-13-2008, 06:53 AM
mso mso is offline
Re: Intrepid
Thanks I will start there and the ground is a good one must check them all the way from the bat Thanks again.
