Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 01-06-2008, 01:36 AM
MLCoop21 MLCoop21 is offline
z32 help!
Hi this is my first post, I have a problem and have no where else to turn so hear gos. My 300zx twin turbo was running fine the other day, but as of yesterday not so well. I succesfuly tryed to override the safty-boost by sticking a paper clip in a connector as adviesed on the internet, and it worked. Till i pulled it out, then it started down hill, the boost gauge reads -14 psi all the time no matter what RPMs. and to make matters worse if the car gos over 4k RPMs it bogs down real bad It just wont go. Witch is strange because the car revs up real nice when in nutral. what should i do?
Old 01-06-2008, 04:32 AM
Broke_as_****'s Avatar
Broke_as_**** Broke_as_**** is offline
Re: z32 help!
If you by passed the detonation sensor (which what I would imagine that internet advice referred to, otherwise figure out which sensor it was) then you'll likely find the ECU putting out a code 34 in the self diagnostic mode. For instructions on check codes:
http://www.ttzd.com/tech/diagnostictech.html
The factory vacuum gauge reading -14 all the time is likely a broken hose going to the sensor. It looks like this:
http://www.z32photoguide.com/electrical.html#boostsend
and is located inside the engine bay against the drivers side fender back by the firewall.
Is there any other symptoms?
1989 240SX Fastback. . . . . . . . . . . . . . . . . . . . . . . . . . . 1995 300ZX Twin Turbo
Warning: Objects in mirror aren't as fast as they thought they were.
Old 01-09-2008, 02:57 AM
Hodo Hodo is offline
Re: z32 help!
And broke is smack dead on.
Finaly got pics of my car....... after I washed it of course.
