Old 01-06-2008, 12:27 AM
rjeffery rjeffery is offline
Dipstick Questions
1st question - Do the holes in the crosshatched area of the oil dipstick represent anything (such as 1 quart intervals)?
2nd question - How low is too low? Is any level within the crosshatched area ok, or should it stay above a certain hole on the dipstick ect?
Thanks!
2002 1500 Ext. Cab 4.8L 2wd.
K&N FIPK, Cat Back Exhaust, Rancho RSX Shocks, Silverstar Headlights High & Low, Infinity Reference Door Speakers & 10" Dual Voice Coil Sub. 265/75/16 BFG AT/KO's, Spray-In Bed Liner, Hella FF75 Fog Lights, Hella FF75 Driving Lights.
Old 01-06-2008, 04:27 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Dipstick Questions
Depends on how many holes. Usually the crosshatched area is 1 qt top to bottom, at least on an engine this size. A very small or very large engine may be different.
The crosshatched area is the fill range. Anything in that range is fine.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 01-07-2008, 12:53 AM
OK, I just wanted to make sure that it wasn't 1 quart per hole.
Thanks.
