Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 01-05-2008, 11:20 PM
karderk karderk is offline
96 pick-up starting problems
Hi guys....I have a strange one for you. My truck was running fine with no trouble lights. Went to start it and there was no noise . Acc/ headlights all working fine . Switched out starter relay and checked for loose wiring, still nothing. Next morning the engine started normally and did so during the day,until it was time for work then again I turned the key and no noise ( may-be 1 small click ).....Now I am lost . hope you can help thanks ( 96 1500,318 )
Old 01-06-2008, 12:09 PM
Slade901's Avatar
Slade901 Slade901 is offline
Banned
Re: 96 pick-up starting problems
Check your battery cable on the battery post itself. It might be just enough to turn on some lights and sometimes enough to allow the engine to crank. Check the cables to the starter. It seems just a loose connection problem.
Old 01-06-2008, 06:57 PM
wayneo69 wayneo69 is offline
try a new starter
Old 01-06-2008, 10:21 PM
Thanks guys ,I will be working on it in the morning
Old 01-09-2008, 11:14 AM
rockwood84 rockwood84 is offline
a dodge has to have a good hot battery to start one its been like that for 50 years . ain't no wimpy battery gonna start one even more so when it is cold .get your battery checked . if the battery checks out then get the alternator output checked.but i betting on the battery being bad as it will crank it when it the outside temp is warmer.
