Parts list/application/source
I thought we should have a place to list replacement/repair parts sources. Many of the parts are generic parts. Some of them are from production cars too. As you find parts sources, list them here. Of course, Gary Jones Motorsports is supporting these cars and we should support his business.
Windshield - From a 99 Mustang. Find it in most junk yards or auto glass vendors. Clutch cable - Fox body Mustang GT (87-93). (I think , correct me if I'm wrong)Transmission seals and parts. The trans is a Temec 3550. Tremec changed the model numbers of these a few years ago. Parts are available here. Standard Transmission. Last edited by Gatorac; 01-10-2008 at 04:45 PM. |
Re: Parts list/application/source
Thanks Jim... I have a spare windshield as the one in my car now is cracked but on the right side so it should still pass tech.
Apparently these things like to crack windshields.
Brian B. Panoz GTRA - LS1 swap in progress #4 Z06 - NASA ST3/TT3 Last edited by Cobra4B; 01-08-2008 at 01:49 PM. |
Motor Mounts - These are from a Fox body Mustang GT. 93 Mustang GT should get you what you need. This is for the GT-RA. Your application may vary.
![]() There are two different styles of mounts used on the GTRA. Mine uses the Fox body mounts. Last edited by Gatorac; 06-08-2009 at 01:19 PM. |
Brembo brakes on school cars use PFC pads.
Brake pad P/Ns PFC front 7780.97.18.44 rear 0592.97.15.44
Jerry 1999 Panoz GT-RA |
Do you know if the solid mounts can be used? What would be recommended? The rubber mounts seems to wear out quickly, but the solid mounts will transmit a lot more vibration to the frame structural members.
Thanks guys... I'm keeping a "misc info" doc in my panoz folder. Jim thanks again for putting all the info up online. Having the owners manual and the parts manual will make ownership 100x easier.
I'm sure a fox mustang specific solid mount exists... I'll ask my buddies at PAS and get back to you guys.
www.performanceautosport.com They specialize in road race mustangs.
Brian B. Panoz GTRA - LS1 swap in progress #4 Z06 - NASA ST3/TT3 Last edited by Cobra4B; 01-08-2008 at 01:50 PM. |
A few companies make solid mounts: http://www.uprproducts.com/shopping/shopexd.asp?id=355
![]() Quote:
Brian B. Panoz GTRA - LS1 swap in progress #4 Z06 - NASA ST3/TT3 |
Thanks guys. I think I'll evaluate the frame members where the motor mounts attach. If they pass the once over, I may go with solid mounts.
My rubber ones are fine... look fairly new, but I'll most likely go w/ solids to keep the motor stable and plan for a future higher power mill.
Fuel pump - currently available from Gary Jones Motorsport for a very fair price.
Have Fun Jim Pomroy 96 Miata track car. 2012 Camaro SS. Backdraft Racing Cobra #930 92 Miata "LemonDrop" ![]() Saturn V Rocket Miata Crapcan #81 99 Miata daily driver. |
This forum is a great reference. I am hoping to compile alot of this information and put it on a web site as a reference to Panoz owners. Here are some parts numbers (and pad interchange) on some of the brake components on the GTRAs:
Front brakes calipers: Brembo (sometimes called Viper or F40 calipers) Front brake pads: Performance Fiction 7780.97.18.44 Interchange series: Brembo 1976, Hawk HB-193, Pagid 1287, 2179 Fits Brembo 20.4862.08/08 Calipers (FMSI D810, D968) used on: 1999-2003 Aston Martin DB7 2003-05 Dodge Viper 1988-95 Ferrari F40 / F50, 1998-2000 Ferrari Modena 2000-03 Jaguar XK R, 2003-04 Jaguar XK 8 / XK Coupe 1997-2003 Lamborghini Diablo Front rotors: 2 piece Performance Friction floating rotor 12.91"x1.25" 328.32.0050.01 (left) and 328.32.0050.02 (right) Rear rotors: 2 piece Performance Friction floating rotor 12.91"x1.1" 328.28.0050.01 (left) and 328.28.0050.02 (right) From what I understand, PF doesnt make the 97 pad compound any longer. From their description, it sounds like a street/track pad. I plan on switching to something more aggressive once we use up the "stock" pads. I will see if I can find some interchange pads for the rears since I just found the part number in this thread. |
Thanks for the data dump. I agree that the best use of this forum is the exchange of info on parts, processes to fix things, and general info on these bad ass cars.
I've used PFC pads for my Z06 for over 3 years. No complaints. The pads were great for cross purpose use of driving on the road and track use. But for a dedicated track car, a set of Hawk pads might be superior. Any additional info will be very much appreciated.
I cant find anything definitive on the rear brakes, but it looks like the pads may interchange with the Hawk 194.570. These are from 92-02 Vipers, CTS-Vs, and the 2000 Cobra R Mustang. Can anyone verify this is the rear pad? The Hawk pad is at the top and the PF pad is at the bottom. They look the same to me.
Dont know if Gary picked up any pads, but considering the racing pads are about $250/axle, the "stock" PF might be a good option. ![]()
