Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Avalanche
Old 01-05-2008, 04:52 PM
lousberg lousberg is offline
transmission problem
I have an 02 avelanche with service engine light on.
I had the codes read they read:
P0740 Torque Converter clutch circuit malfunction
P0785 Shift/timing solenoid malfunction
P1860 TCC PWM solenoid electrical fault
Can someone tell me if I could just replace the torque converter and other parts that read or does the whole transmission need rebuilt?
Thanks
Dan
Old 01-05-2008, 08:37 PM
Jaywyatt Jaywyatt is offline
Re: transmission problem
You most likely have a bad ignition switch. A common problem on that model.
Document ID# 1371241
2002 Chevrolet Avalanche - 2WD
Malfunction Indicator Lamp (MIL) On, Transmission Stuck in Third Gear, Insrument Cluster Inoperative (Replace Ignition Switch) #01-07-30-002C - (Aug 21, 2003)
Malfunction Indicator Lamp (MIL) On, Transmission Stuck in Third Gear, Instrument Cluster Inoperative (Replace Ignition Switch)
1999-2000 Cadillac Escalade
2002-2003 Cadillac Escalade, Escalade EXT
2003 Cadillac ESV
1997-1999 Chevrolet Full-Size Pickup, Suburban, Tahoe (Old Style)
1997-2003 Chevrolet Blazer, Express, S-10
1999-2003 Chevrolet Silverado, Suburban, Tahoe (New Style)
1999-2003 Chevrolet Blazer RH Drive (Export)
2002-2003 Chevrolet Avalanche, TrailBlazer, TrailBlazer EXT
1997-1999 GMC Sierra, Suburban, Yukon (Old Style)
1997-2001 GMC Jimmy
1997-2003 GMC Savana, Sonoma
1999-2003 GMC Sierra, Yukon, Yukon XL (New Style)
2002-2003 GMC Envoy, Envoy XL
1997-2003 Oldsmobile Bravada
2002-2003 Oldsmobile Bravada
with 4L60-E or 4L65-E Automatic Transmission (RPOs M30, M32)
This bulletin is being revised to update the model years and to add additional models. Please discard Corporate Bulletin Number 01-07-30-002B (Section 07 -- Transmission/Transaxle).
Condition
Some customers may comment on one or more of the following conditions:
* The Malfunction Indicator Lamp (MIL) is ON.
* The transmission is stuck in third gear.
* The instrument cluster is inoperative.
Upon investigation, one or all of the diagnostic trouble codes (DTCs) P0740, P0753, P0758, P0785, P1860 may be set.
Cause
The most likely cause of this condition may be a loss of power to the transmission on circuit 1020. This loss of power may be caused by an open in the ignition switch. This condition may also be the result of an incorrect installation of an aftermarket electronic device such as a remote starter or alarm system.
Correction
With the ignition switch in the RUN position, test for battery voltage at the appropriate fuse listed below.
[Edited out chart]
Ignition 0 For the C/K trucks. (2002~2006)
[End edit]
If battery voltage is present at the fuse, inspect circuit 1020 between the fuse and the transmission for possible opens. If battery voltage is not present at the fuse, replace the ignition switch using the Ignition Switch Replacement procedure in the Steering Wheel and Column sub-section of the applicable Service Manual. Refer to group number 2.188 of the parts catalog for part description and usage.
If the vehicle is equipped with an aftermarket electronic device and the DTCs are being set when the device is being used, verify that the appropriate fuse listed above is being supplied battery voltage during operation. If voltage is not present at this fuse, these DTCs will be set due to lack of power at the solenoids. This condition is most likely to occur with an incorrectly installed remote starting system. If this is the case, refer the customer to the installer of the system for corrections.
Old 01-10-2008, 08:24 PM
Thanks for the info I do have power at Ignition 0. I am not shure how to check circuit 1020 or where it is a little help please thank you.
Old 01-11-2008, 12:24 AM
16th hippy 16th hippy is offline
the connector for this in on the passenger side of trans. you will need to remove the heat shield(makes it easier, but if you have small hands and don't break the connector is ok to leave it on). 2 10mm bolts. i don't remember what wire it is, hopefully somone can help. next question is how much power was there? the full battery voltage?
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle.
Old 01-11-2008, 01:32 AM
Thanks I just used a light I will get a volt meter and check.
Old 01-11-2008, 02:15 AM
OK the volt meter read 11.5 volts
Old 01-11-2008, 06:02 AM
Do you have the problem all the time? Trans. will be stuck in 2nd gear and will not shift. If trans. is shifting ok the problem is not happening at the moment, allthough the light will still be on until the ECM is cleared.The only way to clear it is with a scan tool.It is probably loosing power from the ignition switch intermittantly. You should monitor the IGN 0 fuse circuit with a test light while driving and see if it looses power. Here is a wiring diagram if it is of any help.
Old 01-11-2008, 07:45 PM
I had the codes cleared.Put an led light on ignition o and the light stays on. The trany is shifting perfect. It does have a remote start it has been on for five years do you think it could be the problem
Old 01-12-2008, 08:49 AM
Has the service engine light came back on since the codes were cleared?
Old 01-14-2008, 12:31 AM
No the light has not come on. I have only made a few trips to town its been 20 below dont drive alot.Wait and see. Tanks
