Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 01-05-2008, 04:43 PM
dragonmaster169 dragonmaster169 is offline
Oil pan plug size?
Hello all,
Trying to change the oil on a 1999 isuzu rodeo ls. Does anyone know the size of the oil pan plug, its on there pretty tight and i cant get it off.
thanks
Old 02-04-2008, 09:27 PM
Isuzuworshipper's Avatar
Isuzuworshipper Isuzuworshipper is offline
Re: Oil pan plug size?
Not sure if it's the same as my 93. Last time I checked, it was 20mm and I ended up using a large adjustable crescent wrench.
Old 02-23-2008, 09:50 PM
rambo1214's Avatar
rambo1214 rambo1214 is offline
Mine was a 22mm the aftermarket replacement is a 17mm
Jen
99 Isuzu Rodeo 2.2L 4Cyl. 5 Spd.
99 Isuzu Rodeo 3.2L 6Cyl. 4x4 5 Spd.
Rodeo 2 towing Rodeo 1
Old 02-26-2008, 03:27 PM
stantony1 stantony1 is offline
Also use the power of levereage.
I keep 3/4 copper pipe 1-2 feet long and put that on the end of the socket wrench. It makes it way easier to remove the plug.
Careful when tightening. Don't use the pipe for that. It will over tighten.
Cheers
Old 03-12-2008, 10:53 PM
rod2004 rod2004 is offline
mine is a rodeo 2004 and pan plug size is 22mm.
2004 rodeo 3.2L 2WD
AISIN AT
http://www.isuzufaq.com/
http://forum.planetisuzoo.com/
http://isuzuforums.com/
