Go Back   Automotive Forums Car Chat > Buick > Regal
Old 01-05-2008, 04:26 PM
89oldsregancy 89oldsregancy is offline
Power steering stiff when cold
When I start my car in the morning and begin to drive to work i have a really stiff spot in my power steering inbetween 10 and 2 oclock im not sure what is causing this
its a 2001 buick regal GS
Old 01-06-2008, 09:45 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Power steering stiff when cold
What is your weather like? Did you check power steering reservoir fluid level?
Timeslip 08/12/06
AF Community Guidelines
Old 01-06-2008, 02:05 PM
Fluid level is fine weath is about 32f 0 c
but there is still a stiff spot when the car is warm
Old 01-07-2008, 05:52 AM
BNaylor's Avatar
Rack and Pinion. There were some GM TSBs covering a similar issue for earlier Regals but not sure if it is applicable to the 2001 model. Do you have the variable ratio/assist steering option.
Timeslip 08/12/06
Old 01-07-2008, 10:29 PM
grandamdriver52's Avatar
grandamdriver52 grandamdriver52 is offline
Send a message via AIM to grandamdriver52 Send a message via MSN to grandamdriver52
I know on the older models (94-96) it was normal to do that until they warmed up.
1995 WaveRaider 1100 - Primer kit, Ocean Pro Vortex flame arrestors, R&D 155 PSI Race Head, Jettrim seat, 5 degree nozzle, Cut stock water intake grate, Solas 13/19 Impeller, hydro-turf, pro-tec ride plate, Riva Racing handlebars, billit throttle, rebuilt mukuni SBN 38's.
Riding a WaveRaider is like riding a p***ed-off paper plate
Old 01-07-2008, 10:52 PM
stripe stripe is offline
I have a 98 it does the same thing till it is warm.
Cheers
Old 01-08-2008, 06:12 AM
BNaylor's Avatar
I've got a '99 LS and '01 GS. Neither one of them ever have the problem OP stated even when temps get down into the 20s and according to his last post "still has a stiff spot when the car is warm". Doesn't sound normal to me.
Timeslip 08/12/06
