Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 01-05-2008, 01:35 PM
lbagley lbagley is offline
fuel filter
Where is the fuel filter on a 2005 suburban?
Old 01-05-2008, 01:42 PM
j cAT j cAT is offline
Re: fuel filter
should be drivers side frame rail about mid point of vehicle.must get under vehicle, under drive shaft.filter inside of frame rail.....if you are going to do this have plugs ready as lots of fuel will come out, unless your fuel pump check valve is bad..........
Old 01-06-2008, 01:55 PM
east302 east302 is offline
Re: fuel filter
I think (for 2004?) they started putting the fuel filter in the gas tank. It isn't serviceable. On my 2003 it is on the frame rail like J Cat said.
Old 01-06-2008, 04:33 PM
Re: fuel filter
the fuel pump assembly has a tank filter but this is a screen . the frame rail mounted filter is the can type..
Old 01-08-2008, 04:40 AM
16th hippy 16th hippy is offline
Re: fuel filter
for 04 it could be anybodys guess as i forgot for sure, bu in 05 only the z-motor(some 5.3's 10th digit in VIN is Z) had an external filter. all others are in tank best of knowledge. but to be sure, on gas engines it will be on the frame rail just behind the EBCM(ABS brake modulator/brain) if external filter.
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle.
