1996 grand am 2.4 has misfire on 1 and 3.changed coils. coil housing ,plugs,ingintion control module.plug caps, swapped injectors,shows same code mis fire on 1 and 3 dont know what to do now
Re: misfire
Did you clear the code(s) when you replaced those items you listed above?
You could have clogged injectors or a wire shorted out.
1999 Grand Am SS 3.4 OHV
Re: misfire
codes were cleared po301and po303 looked for short cant find anything
Re: misfire
check the cam sensor and make sure the gound wire for the module is good the braided one under the cover over the plugs.
Re: misfire
If the cam sensor was the problem, he would most likly get a DTC for that, not a msfire.
![]() Check the Ohm resistance on the injectors, paying attention to their difference's.
