Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 01-05-2008, 09:01 AM
lsuman24 lsuman24 is offline
Help Please! car stalls at idle and while driving
Ok I am having a problem with my only vehicle. I have a 1989 Delta 88. The car is or was a great car but recently it dies while driving and if left to run idle for too long. I will be driving and suddenly I get a temp light then 15 seconds or so it dies. I wait anywhre from 1 minute to an hour then it restarts it is completely random, did it real bad a few weeks ago then stopped now its doing it again. Tried thermostat, fuel system,. Also last winter it did this like 2 or 3 times then spring rolled around and it didn't do it again till just recently and it is winter in Iowa again I DONT GET THIS. seem to be temp related but only during winter? LOST ANY IDEAS WOULD BE GREATLY APPRECIATED.
Also checked spark and fuel both are there?
Old 01-05-2008, 09:21 AM
G.A.S. G.A.S. is offline
Re: Help Please!
the temp light may be an unrelated issue as when a car stalls, or starts to stall, the dash lights, or some of them, come on.
I know you see fuel in the carb but My first check would be the fuel filter in the carb.
Old 01-05-2008, 09:48 AM
Re: Help Please!
So the fuel filter hmm will try that......guess I dont understand why it only happens when it gets hot but thanks will try that when I get off work
Old 01-05-2008, 09:54 AM
Re: Help Please!
It is not the heat that triggers a filter problem, in that style car and that symptom that go together.
When the fuel is pressurized, it pushes dirt/sludge or whatever into the filter. When there is no pressure, (the car is off) the dirt setteles and fuel will be allowed to pass through the media(filter).
So, you could start your car, drive it for a short time and have this occure. and at any time.You may go 10 min. You may go 2 or even 30 or even sitting at an idel
Old 01-05-2008, 10:10 AM
Re: Help Please!
AHHH I see thank you so do you think the weather is just a coincidence as the only times it has happened was during winter. Either way fuel filter is getting replaced this afternoon
Old 01-05-2008, 11:18 AM
Re: Help Please!
Ok just got done replacing filter no luck ran for 10 minutes died same thing fuel flow pressure is there and spark as well Thanks again though.
