Old 01-05-2008, 08:05 AM
joslinm joslinm is offline
92 Grand Am pulling right
Is there anything that could cause this besides air pressure and or alignment?
Old 01-05-2008, 10:00 AM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: 92 Grand Am pulling right
If you had a spring broke it could cause pulling to one side or the other.
Most likly it is allignment, unless you've been out off roading.
1999 Grand Am SS 3.4 OHV
Old 01-05-2008, 05:51 PM
I looked it over real good and didn't find anything broken. I would think it was the alignment, but the tires are wearing fine.
Old 01-05-2008, 05:59 PM
Tire wear doesnt always matter , it migth not be that far out but enough to pull to one side.
The only way to tell is to properly measure the toe and camber, not something you can do at home unfortunatly.
I guess a brake draggin , malfunctioning calipers - could also cause pull.
If the front tires are two different sizes, or the obvious low tire pull.
Old 01-06-2008, 03:24 PM
Found a broken sway bar link on the LEFT side. Caused the car to pull right all the time. Fixed and driving straight again. 5 bucks.
