Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 01-05-2008, 08:45 AM
UMMA UMMA is offline
99 GC Driver mirror replacement
Greetings,
My 99 GC mirror is broken, so I need to replace it. Unfortunatly, that is over $400 at the dealer and I am having a hard time finding a replacement. I need the 8 pin version (heat, memory, auto tint). Will a less expensive mirror that does not have memory fit?
Thanks
Old 01-05-2008, 09:45 PM
reekor reekor is offline
Re: 99 GC Driver mirror replacement
More info needed. In what way is the mirror broken?
Originally Posted by UMMA
Greetings,
Thanks
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 01-05-2008, 09:57 PM
The glass cracked, a fluid leaked from the mirror (i believe this was for the auto dimming) and there are a few cracks on the plastic that holds the actual glass. Hope this helps.
Regards
Old 01-05-2008, 10:24 PM
I have a couple of 96's and both have leaked out also. You can pop a Heated none memory mirror in there. You will need to use your old wiring harness and leave the auto dim unplugged behind the mirror. The memory is motor driven so that should work just fine. The most simple way to go about it is just to replace the glass itself. See link
http://www.wjjeeps.com/mirrors2.htm#GLASSREPL
Regards
Old 01-06-2008, 08:22 AM
I appreciate the information Reekor.
Regards,
