Old 01-04-2008, 08:54 PM
Crackhedbob341's Avatar
Crackhedbob341 Crackhedbob341 is offline
smoke from one side of my exhaust
on days that it rains, or when it's cold i sometimes get white smoke that i can see out of the back. i was driving home from work last night, and my friend was behind me and said a big cloud of white smoke came out of my exhaust when i gunned it, but from only one side. my sisters boyfriend said a long time ago it could be an 02 sensor going bad, but i REALLY don't trust his opinion. is something clogged do you guys think?
i know white smoke = coolant generally speaking, but it only happens on certain days, and i don't know if it's normal or not for the car to smoke. i do have the dual exhaust btw.
Never bring show to a go fight.
And a TT conversion brewing..
Old 01-04-2008, 11:34 PM
AutostradaVR4 AutostradaVR4 is offline
Re: smoke from one side of my exhaust
that's just the way our exhaust's are routed. almost all the flow ends up coming out of the driver's side.
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 01-05-2008, 01:02 AM
95DodgeAvenger95's Avatar
95DodgeAvenger95 95DodgeAvenger95 is offline
Send a message via AIM to 95DodgeAvenger95
white smoke is coolant and or moisture burning i belive so if its when its cold or rainy that could be it.
Black 96 3000Gt Vr4 58k mi, H.H.H. Data logger, RPS MAX, Big16G/14b Combo, FMIC, AEM EUGO, Greddy EBC, SAFC II, 560's, hotwired 255lph, not cats, Solid motor mounts, Faze boost gauge, Apexi turbo timer, full exhaust with 3" ICH Single shot Catback, K&N Air Filter, Front upper strut brace, T-Case Bracket, AC delete, Meth injection, NGK stg 1 colder, 8k HID'S.
AIMING FOR 500+AWHP at ips dyno.
Old 01-05-2008, 12:43 PM
Girly VR-4 Girly VR-4 is offline
our cars aren't TRUE dual exhaust... it's a single exhaust, Y'd into a dual near the rear of the car. So at idle, and sometimes during driving, most of the exhaust comes out the drivers side.
As for a big puff of smoke... if your car had been idling for a while before hand, or if you hadn't driven it in a while, it will puff from moisture, if your valve stem seals are going bad (to check if this is teh case, drive the car, park it, let it idle for a little while, then give it gas, if it smokes, it's more than likely your VSS).
www.groundzeroperformance.com
www.3swarehouse.com
1991 Stealth R/T Twin Turbo... sitting...
1996 Orchid Pearl Stealth R/T.... daily driver duty, 275k+ miles and counting!
1995 3000GT Spyder SL... being modified...
Old 01-05-2008, 03:02 PM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
Well the stock system doesn't Y towards the rear. It runs into the drivers side muffler, and then back out the passenger side muffler, at least on the TT's, I assume NA's are the same way.
Also, VSS smoke will be tinted blue.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 01-05-2008, 03:36 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Yes, but 99% of people call it white not knowing any better.
Old 01-05-2008, 04:01 PM
well that cleared up a lot. thanks guys!! yes, i did let my car idle a bit before i started driving. i started it and was running through my mp3 player to find music. it's not a repetative problem, so i dont think its VSS.
