Old 01-04-2008, 08:11 PM
mboy1928 mboy1928 is offline
piz help me 454
hi i have a 82 c10 with a 454 it is 4x4 and i was wonting to put a manual transmission in it what kind of transmission would work
think you
Old 01-06-2008, 04:18 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: piz help me 454
You actually have an '82 K10. In the C/K series, C dentoes 2wd and K denotes 4x4. It is my understanding that any transmission that will fit behind a GM V8 will work (I think late '70-mid '90 are the same?) . With a big engine, you will want transmission designed for all that power. Just remember you will have to replace the flexplate with a flywheel, and you should lower the idle RPM the the manual specs.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
