Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Exterior and Wheels
Exterior and Wheels This is the place for all exterior wheel modifcations.
Old 01-04-2008, 08:02 PM
95dsm1g 95dsm1g is offline
Electrical problem, please help!
Hello,
i own a 1995 GST with at 6 bolt swap. Recently my dash, tail lights, and corner lights went out on my car. The tail lights only seem to work when i press the brake and the signals only work when i hit the switch for them. My dash doesnt light up at all. I checked all the fuses in the engine compartment and the interior under the steering colum. Does any one have an idea of what the problem is?
Old 01-04-2008, 08:10 PM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
Re: Electrical problem, please help!
Originally Posted by 95dsm1g
Hello,
Sounds like its going to be a blwn relay (big black squares in fuse box.) The guys here can correct me but I'm guessing its the Tail Lamp Relay.
'98 Contuor SE, 2.5 V6 Auto Silver
'08 Altima 2.5S, Auto Super Black
Old 01-04-2008, 08:15 PM
where can i get a new relay?
Old 01-04-2008, 10:42 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Any autoparts store or the stealership.
95 Talon TSI AWD
97 Eclipse GST
Old 01-05-2008, 11:14 AM
JoeShmoe's Avatar
Wit, don't jsut go buying things at random. Make sure you don't have a short somewhere cause if you do you will blow that relay ever time. Everytime you turn your lights on it would blow that relay.
Old 01-05-2008, 12:23 PM
no relays are blown, and fuses dont blow whenever i turn the lights on. Im thinkings it might just be the dimmer switch thats bad. it has to be a short since they do work when i turn them on for other purposes
Old 01-05-2008, 12:33 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Your parking lights and tail lamps dont run off the dimmer. That may fix your gauge lights.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 01-05-2008, 01:15 PM
JoeShmoe's Avatar
Yeah I agree, If you just jump it together it should fix your cluster but not your outside lights man.
Old 01-22-2009, 10:59 AM
jgg87_gsx jgg87_gsx is offline
does all your interior lights turn on?
