Old 01-04-2008, 07:31 PM
rockwood84 rockwood84 is offline
does anyone know how the trans cooling lines come loose '02 silverado 2500hd?
i was looking at the trans cooling lines on the radiator and i saw a cap deal on the line before the fitting on radiator do these pop off to get to the quick connect? thanks
Old 01-05-2008, 06:45 AM
16th hippy 16th hippy is offline
Re: does anyone know how the trans cooling lines come loose '02 silverado 2500hd?
the little black cap pops off(remains on the line but can be slid back), to reveal the oh shit clips as they are called sometimes. just be sure to put the little covers back when done.
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle.
Old 01-05-2008, 12:43 PM
the caps on mine are silver colored and have a slot in each side. look like they are aluminum
Old 01-06-2008, 04:49 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Color/material aside, he is correct.
The best way to remove the clips is with a 90 degree pick and needle nose pliers. Get the pick under one side of the clip, and pull just far enough to get the pliers on the middle raised part. Use the pick to release the other side of the clip and pull off. If you don't release both sides, the pliers have a tendancy to slip off. Best case scenario, it snaps back on. Worst, it falls and you don't hear it hit the ground.
With the clip gone, the line should just pull out.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 01-08-2008, 04:24 AM
hence the name they have earned...lol.
Old 01-08-2008, 05:40 PM
masapell's Avatar
masapell masapell is offline
Fortunately, when I pulled mine off, I had been told by a tech from the Chevy house to keep a good grasp on that little clip or it would be gone forever!!!
2014 Ram 1500 Crew Cab
Old 01-09-2008, 09:46 AM
o.k. got rad out and drivers side tank on and back in . them clips are what i expected from a g.m. [fun to work with ] the tank had a trhee inch split at the top oil cooling line . only thing good out of this was the tank was replacable without replacing the whole rad. thanks for the clips 101
Old 01-09-2008, 03:28 PM
no prob, glad you got it fixed.
Old 01-10-2008, 11:53 AM
hey the clips were not that bad .i used a stiff piece of wire beat the end flat and put a bend on it and hooked one end and popped it out and grabbed it with needle nose. all i can say for the rad is damn what a rad and i can see why they want so much for them.but again thanks for the tips and replies
