Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 01-04-2008, 05:58 PM
jchew22 jchew22 is offline
wet carpet
the carpet under my drivers seat keeps getting soaked it happens when it rains or the ground is wet. are there any vent hole under that part of the car? i looked but couldnt see where it might come from. is there a way to lift up the carpet and loook?
Old 01-04-2008, 10:10 PM
Jrs3800 Jrs3800 is offline
Re: wet carpet
Being that you have an 00+ you may possibly have a door thats leaking into the car... The door drain system is actually set up behind the door panel... There will be a bead seal of sorts that will have to be cleaned, as well as the doors surface and resealed to kill off the leaks... That unless you have a sunroof... If you have the sunroof there is a chance that it could the a sunroof drain...
Good Luck
Old 01-05-2008, 05:33 AM
jdq jdq is offline
Re: wet carpet
What year? I had the sunroof leak out of 3 of the 4 drains, and these cars are known for door seals leaking.
2000 bonn ssei 155000 klm
1997 dodge caravan 92000 klm
Old 01-05-2008, 08:29 AM
Re: wet carpet
2005 i think it is a door leak
Old 01-05-2008, 08:44 PM
Re: wet carpet
If thats the case the sheet behind the door panel will have to be resealed..
Old 02-19-2008, 07:16 PM
[email protected] i40741@aol.com is offline
Re: wet carpet
mine does too but we get wet floors to the extent of 3 or 4 inches of water in back floorbord, we finally shot holes in the back floor bord with a 22 and it still gets wet but not deep
Old 02-19-2008, 11:00 PM
Re: wet carpet
What year is this car.... The leaks on these cars varies between the Different designs.. And some of them can and will have a lot of electrical issues if the problem is not solved.. In some cases this can cause the air bags to deploy while driving...
